008MB's avatar
008MB
How to Disable remote login
I can't seem to disable remote login to admin.  i.e.  using my phone with wifi on I can login to admin via 192.168.1.1    shouldn't i be able to disable this access?
Mike
  • the 192.168.1.1 isn't remote access. Its local access meaning on your network.
    Remote access is access external to your network.
  • plemans's avatar
    • 008MB's avatar
      008MB
      Right,  I mistakenly said "Remote Access"
      I have a linksys router and I can block admin access via wifi, so, how do I do this on the R6230?
      Mike
      • > I have a linksys router [...]
           Thanks for the detailed description.
        > [...] and I can block admin access via wifi, so, how do I do this on
        > the R6230?
           Not an option which I've seen on any Netgear router.  The "admin"
        password is the only restriction I've seen.
  • > Model: R6230|AC1200 Smart WiFi Router Dual Band Gigabit
       Is that accurate?  Firmware version?
    > with wifi on I can login to admin via 192.168.1.1 [...]
       Define "remote".
       What makes you think that your "my phone" is "remote" when you're
    "using my phone with wifi"?  Or that any "remote" device could
    communicate with your router at a private address like "192.168.1.1"?
       Visit http://netgear.com/support , put in your model number, and look
    for Documentation.  Get the User Manual.  Read.  Look for "Remote
    Management".
       Then, using your cellular-telephone data connection rather than a
    wireless connection to your own router, try again.
