Tom2112's avatar
Tom2112
How to disable WPA3 and enable WPA2 only on WAX630E access point?
I have a Netgear WAX630E access point running firmware v10.8.11.4 that I do not have connected to cloud management. The local management interface only has four options for wireless authentication: none (open), WPA3 Personal, WPA3 Enterprise, and WPA3/WPA2 Personal. I need to disable WPA3 and only use WPA2 personal because I have devices that are not WPA3 compatible and refuse to connect with WPA3 enabled.
How can I disable WPA3 and only have WPA2 enabled?
  • Create the SSID for only 2.4Ghz and 5Ghz Radios.
    Only WPA3 is allowed on 6Ghz as per Wi-Fi standards.
    If 2.4Ghz/5Ghz/6Ghz is enabled one the SSID,  then WPA2/WPA3 is the minimum that is allowed
    One common way to achieve this is to create two SSIDs linked to the same wired network.
    One WPA3_only SSID is for newer Wi-Fi clients, and another WAP2_only SSID is for legacy Wi-Fi clients.
  • hnagaraju's avatar
    hnagaraju
    NETGEAR Employee Retired
    • Tom2112's avatar
      Tom2112
      Thank you, hnagaraju!
      That worked perfectly! I should have realized the 6 GHz part of it was messing me up. As soon as I disabled 6 GHz (which I wasn't using anyway), I could select WPA2 personal only.
ProSupport for Business
