ahmedmeall
Feb 26, 2023Aspirant
how to increase wifi range 500 meters
Hi, I want to increase the WIFI range by 500 meters circle, which gadget use to increase the range, Is any expert opinion needed?
Feb 27, 2023Guru - Experienced User
You're not going to cover 500meters with a single router/access point solution.
500 meters is a lot of coverage. You'd need quite a fewl access points.
A 500m circle has 196,000 meters of coverage. That's a lot.
So maybe a better idea is to go over what you're trying to actually do to see if you need that much coverage and what you're trying to accomplish
