Malvineous
Jul 27, 2023Aspirant
How to make management VLAN on WAX610 persist across power cycles
Hi all, I've gotten a new WAX610 and I want to set it up with two WiFi SSIDs on different VLANs, and with a management VLAN. Unfortunately I can't work out how to make these settings stick - eve...
NiveditaP3
Aug 02, 2023NETGEAR Expert
Hello Malvineous
And welcome to the NETGEAR Community! 🙂
Set the 802.1Q VLAN and management
VLAN
The 802.1Q VLAN protocol on the access point logically separates traffic on the same
physical (wired) network. This protocol can work with tagged and untagged VLANs, as
follows:
• Untagged VLAN. The access point sends untagged frames from its Ethernet interface.
Incoming untagged frames are assigned to the untagged VLAN. By default, the
untagged VLAN is VLAN 1. By default, the access point functions with an untagged
VLAN.
• Tagged VLAN. The access point tags all frames that it sends from its Ethernet
interface. Only the incoming frames that are tagged with known VLAN IDs are
accepted.
The management VLAN is used for managing traffic such as Telnet, SNMP, HTTP, and
HTTPS traffic sent to and from the access point. Frames that belong to the management
VLAN and that are sent over the trunk do not receive an 802.1Q header. If a port is a
member of a single VLAN, its traffic can be untagged.
To set the 802.1Q VLAN and management VLAN:
1. Open a web browser from a computer that is connected to the same network as the
access point or directly to the access point through an Ethernet cable or WiFi
connection.
2. Enter the IP address that is assigned to the access point.
A login window opens.
3. Enter the access point user name and password.
The user name is admin. The password is the one that you specified. The user name
and password are case-sensitive.
If you previously added the access point to a NETGEAR Insight network location and
managed the access point through the Insight app or Insight Cloud portal, enter the
Insight network password for that location.
The Dashboard page displays
Link for reference : https://www.manualslib.com/manual/1865056/Netgear-Wax610.html?page=131
Have a lovely day,
Nivedita Pa
Netgear Team
- MalvineousAug 02, 2023Aspirant
Yes I already read that in the manual, and I am familiar with how VLANs work, but I was asking why the VLAN settings get lost after every reboot. I opened a support case and after one week of back and forth and repeating myself it finally got through to a level 3 technician who followed my instructions and confirmed that there is a bug in the firmware that causes this VLAN problem, and they are now working on a fix. Unfortunately there is no ETA on the fix so I had to return the WAX610 for a refund as without this feature it is unusable for me, and I do not wish to buy a product I cannot use for months after its purchase.
I am quite surprised that a company like Netgear would not test their products properly, especially ones sold as business products, but I have learned my lesson and I will stick to other brands in future.
