HappyDaddy007
Feb 20, 2024Tutor
How to quarantine new devices on WAX214
Hello, I'm a dad who is trying to set up parental controls on my kids iPads. They are quite clever and until now are able to find ways around my previously tried methods. I'm settling on tryi...
- Feb 20, 2024
https://www.downloads.netgear.com/files/GDC/WAX214/WAX214_WAX218_UM_EN.pdf
Set up a MAC filter for an SSID, p.84 ff.
https://www.downloads.netgear.com/files/GDC/WAX214v2/WAX214v2_UM_EN.pdf
Manage access to a user WiFi network based on a client’s MAC address, p.56 ff.
Register the physical MAC addresses of all the wireless devices. Knowing the WiFi password alone does not help.
Allow MAC in the List: The MAC addresses that you add to the list are allowed access but all other MAC address are denied access.
Feb 20, 2024Guru - Experienced User
There isn't a way to "quarantine" new devices.
Not sure how it works since I don't have an WAX214 but the nighthawks have the ability to block new devices from accessing.
Another option might be a "if you violate this rule, you lose access for a week" to the wifi. If they're circumventing the security you have in place, it can put you in jeopardy (if they're looking up nefarious things) so they need to be aware of that and judge whether getting caught is worth the risk. Kids are going to try and get around security, we can only do the best we can.
What I have on mine is a pihole that I can put custom blocking lists. It can still be circumvented but it makes them work at it a bit and I can see when they're doing it.
schumaku
Have an eye on the Chapter "Set up a MAC filter for an SSID" with a MAC address that allows access: An ACL with a policy that allows access functions please.
- HappyDaddy007Feb 20, 2024Tutor
Thanks schumaku, I've got 'deny' set on the ACLs for the WAX214 against their iPads, but they just have to know the passwords and switch on private wifi to circumvent this, as this changes the iPad MAC address and allows them in, hence why I was looking for a 'new device' quarantine option.
- plemansFeb 20, 2024Guru - Experienced User
The wax214 is an access point with a router mode(as far as I recall). Any chance you're actually using them as access points that is managed through a different router? Or is one of them in router mode?
If you have a different router acting as gateway, many times that has its own parental controls, access control list.
