HappyDaddy007
Feb 20, 2024Tutor
How to quarantine new devices on WAX214
Hello, I'm a dad who is trying to set up parental controls on my kids iPads. They are quite clever and until now are able to find ways around my previously tried methods. I'm settling on tryi...
- Feb 20, 2024
https://www.downloads.netgear.com/files/GDC/WAX214/WAX214_WAX218_UM_EN.pdf
Set up a MAC filter for an SSID, p.84 ff.
https://www.downloads.netgear.com/files/GDC/WAX214v2/WAX214v2_UM_EN.pdf
Manage access to a user WiFi network based on a client’s MAC address, p.56 ff.
Register the physical MAC addresses of all the wireless devices. Knowing the WiFi password alone does not help.
Allow MAC in the List: The MAC addresses that you add to the list are allowed access but all other MAC address are denied access.
Feb 20, 2024Guru - Experienced User
There isn't a way to "quarantine" new devices.
Not sure how it works since I don't have an WAX214 but the nighthawks have the ability to block new devices from accessing.
Another option might be a "if you violate this rule, you lose access for a week" to the wifi. If they're circumventing the security you have in place, it can put you in jeopardy (if they're looking up nefarious things) so they need to be aware of that and judge whether getting caught is worth the risk. Kids are going to try and get around security, we can only do the best we can.
What I have on mine is a pihole that I can put custom blocking lists. It can still be circumvented but it makes them work at it a bit and I can see when they're doing it.
HappyDaddy007
Feb 20, 2024Tutor
Thanks for the response plemans, I can't see a similar option available for the WAX214 as you've detailed sadly.
Your suggestion for the kids might have to be a fall-back - I basically tell them they're not allowed to enable private WiFi on their iPads, but then they'll know how to circumvent (if they want to risk punishment).
- schumakuFeb 20, 2024Guru - Experienced User
- HappyDaddy007Mar 04, 2024Tutor
So I used some of the tips here, but there is no quarantine feature on the WAX214 (v1). As I've got many devices already using established 2.4 and 5 GHz wifi networks, I've taken off the 'private wifi' setting on the kids' iPads and iPhones, exposing their real MAC addresses, and kept the connections to the established networks intact, so the 'private wifi = off' setting is retained and not forgotten.
On the WAX214, I've then set the ACLs on these wifis to 'Deny' against those MAC addresses.I created new wifi networks with the 'Allow' ACL to only their devices, which I now manage under the wifi scheduler.
I can also use the parental controls on the router to which the WAX214s are connected (a Linksys WRT3200ACM) in order to block specific websites against their MAC addresses, which I don't think is a feature on the WAX214.
Can anyone confirm what security risk is avoided by the use of private wifi 'random' MAC addresses? It's a very annoying feature that makes network management for kids' devices hard to maintain.- schumakuMar 04, 2024Guru - Experienced User
On the WAX214, I've then set the ACLs on these wifis to 'Deny' against those MAC addresses.The consumer devices have some kind of default allow-all MAC address mode, and add the ability to "quarantine" (== block or disallow MAC addresses of unknown devices).
So there -is- a quarantine feature - you have just configured the essentials of it.
Strongly doubt that's the way it really works. There is not MAC address to websites relation, much more that Linksys does monitor the DNS queries coming from the clients in plain text, and return either the correct IP address - or force the Web clients to some portal page saying "no kids, you re not allowed to see this." This works because most of the DNS traffic isn't encrypted or protected. Once your kids figured out on how to configure secured and encrypted DNS, daddy is on it's own alone. In consequence, on top what you implemented with the allowed MAC address list you would have to introduce and end-point-security to all devices. Means -all- mobiles, tablets, home appliances like a Thermomix, ...
it's not about security, it's just about privacy - the privacy you wont allow your kids (or for the sake corporate users) on your very own network. That's also why enterprise network admins are actively pushing security policies (and sometimes applications) to all end points.
