mikey6283's avatar
mikey6283
I want to connect a AP Wax610
Thanks for providing snapshot this really helps newbies.
 i have a same situation where i want to connect a AP Wax610  SSID home network and SSID Guest/IoT 2.4 to port say 5.
I have a Vlan setup using ,802.1Q advanced , however i too are confused on tagging,should port 1 and port 5 be tagged and  remainder untagged in PVID.
Would the Port 1(Lan) be tagged or untagged and port 5 be tagged based on your comment or for simplicity?
Your help would be appreciated.
No RepliesBe the first to reply
ProSupport for Business
