Dpanneer
May 27, 2022Follower
Insight Managed 630 AP shows Waiting for first connect
Trying to connect first netgear 630 AP via insight managed app. have registered netgear account and registered devices. logged in AP local web GUI and configured insight remote management. have ...
Tester92
Jul 22, 2022Initiate
If it is visible in the App means it can be discovered on the LAN only. Is there some security blocking connections towards to the Internet, like some DNS filtering active being on your router, the ISP, or a 3rd party service? If so, you can try temporarily configure your router to use e.g. the Google and/or Cloudflare DNS IPs like 8.8.8.8 resp. 1.1.1.1, at least these addresses should be assigned by the DHCP server to the clients?
