TheGrumpyGent's avatar
Apr 20, 2022
Local Login if Managing Orbi in Insight?
If I register my Orbi Pro with Insight, it changes the credentials (and settings!) locally on the router.  How do you login to the local admin screen, as none of the credentials I have appeared to work?
  • Hi TheGrumpyGent,
    It should be the Device Admin Password which is located on Locations > Location Configuration.
    For your reference, kindly check this KB article.
    JeraldM
    NETGEAR Community Team
  • JeraldM's avatar
    JeraldM
    NETGEAR Employee Retired
    Hi TheGrumpyGent,
    JeraldM
ProSupport for Business
