john_harrold
Mar 26, 2022Tutor
Integrating a WAX610Y wifi access point with my existing network
Hello, I have a RAX120 router and 3 EX8000 extenders in my home. Outside I have an AX1800 (WAX610Y) access point mounted on the side of my house. I've looked through the NetGear Insight app and I...
Mar 26, 2022Guru - Experienced User
My understanding of the insight devices is that they mesh with other insight devices. Not the consumer devices.
I could be wrong on that but you'd get better help by asking on the insight/business wifi forum.
https://community.netgear.com/t5/Business-Wireless/bd-p/business-wireless-for-business
schumaku
Mar 27, 2022Guru - Experienced User
Yes, plemans is correct. To operate WAC5xx or WAX6xx Insight instant Mesh wireless satellite(s), another WAC5xx or WAX6xx in a wired config must be in reach of the WAX610Y.
The Insight AP offer however full interoperability over all generations, AC, AX, ... so tech updates can be deployed easily without replacing complete network as we know from consumer and business Mesh systems.
- john_harroldMar 27, 2022Tutor
I see. Thank you both @plemans and schumaku. Might I trouble the two of you with a few more questions?
I'm thinking about replacing my older range extenders with similar access points. I have a couple questions.
First would the new access points need to be within wifi range of each other? They will both be plugged directly into the network via ethernet, will they be able to mesh successfully this way?
Second, if I understand the two of you correctly, I should be able to get my current WAX610Y to work with any WAX correct?
Again thanks for helping out here. It's difficult to approach this.
- schumakuMar 28, 2022Guru - Experienced User
The Mesh term was badly abused by the WiFi consumer industry resp. marketing. Yes, all WAX6xx (and WAC5xx) provide seamless roaming, being if deployed on your switched wired LAN, or added to these as Insight Mesh extender satellite.
Any WAX6xx can be used as a root for any WAX6XX, including your WAX610Y as an extender satellite..
Don't forget that on the dual-radio models one radio is shared for the wireless infrastructure and the AP, obviously limiting the performance to about 50%.
