tchubaba
Sep 26, 2023Guide
Inter-VLAN routing issue only via Wi-Fi
Recently I purchased the AP WAX630E and switch MS108EUP for my network in order to be able to create VLANs and isolate certain types of devices in the network. I am using these two products along wit...
- Sep 29, 2023
Hi ToniRod . I heard back from Netgear support. They confirmed that the issue is indeed with the WAX630E AP - it does not support Inter-VLAN communications when the devices are connected to the same AP, and they have no plans to add support for it. Apparently the only use case supported for this AP for inter-VLAN wi-fi communications is to use 2 different APs, which kinda doesn't make much sense in my head, but OK I guess. At least now I have confirmation that the issue is indeed where I suspected it was and can move on from here.
tchubaba
Sep 26, 2023Guide
Thank you for taking the time of reading my post and providing your insight. Please keep in mind that I'm new to VLANs and I am indeed trying to take the time to learn and get better at it. I am also trying to understand what is the source of my problem - whether it is the firewall, the switch, the AP, or something misconfigured: thus why I am posting here. So please bear with me as I work through this - I do appreciate your patience.
My intended purpose with this setup, as mentioned, is to segregate devices, and I do have:
LAN (ID tag 1, Management)
VLAN2 USER (ID tag 2, For PCs and Phones)
VLAN3 IOT (ID tag 3, for IoT devices)
In the firewall, LAN has a dedicated port, which is connected to port 3 of the switch. VLAN2 and VLAN3 are both assigned to physical port OPT1 of the firewall, which is connected to port 2 of the switch.
The switch port 4 is connected to the Windows PC, which is supposed to be on the LAN - and it is: it's getting IP 192.168.1.100.
The switch port 5 is connected to the IP camera, which is supposed to be on VLAN3 (IOT) - and it is: it's getting IP 192.168.3.100
VLAN2 (USER) is only ever going to used by Wi-Fi devices - it doesn't need a dedicated port on the switch.
VLAN3 (IOT) is mostly going to be used by Wi-Fi devices, except for the Wired IP camera on switch port 5.
So with the setup I described in the original post, everything is mostly working as intended. The only issue being that when I have 2 Wi-Fi devices on separate VLANs they can't communicate properly. Wired to Wi-Fi communication does work (as long as the firewall rules allow). So:
- Wired LAN PC to Wired VLAN3 camera: OK
- Wired LAN PC to Wi-Fi VLAN3 camera: OK
- Wi-Fi VLAN2 PC to Wired VLAN3 camera: OK
- Wi-Fi VLAN2 PC to Wi-Fi VLAN3 camera: Cannot connect
- Wi-Fi VLAN2 PC to Wi-Fi VLAN3 linux laptop: Cannot connect
- Wi-Fi VLAN 2 PC to Wired VLAN3 linux laptop: OK
And as previously stated, the scenario where I have the linux laptop on Wi-Fi VLAN3 was an attempt to troubleshoot - tcpstat indicated there were incoming requests from Wi-Fi VLAN2 PC, only they would stay stuck on SYN_RECV and never reach ESTABLISHED. If I move the linux laptop to Wired VLAN3, the connection works (the webpage loads in Wi-Fi VLAN2 PC). This is what led me to believe there was a routing issue somewhere in inter-VLAN Wi-fi to Wi-fi connections.
schumaku
Sep 27, 2023Guru - Experienced User
Currently, there are no uplinks configured for VLAN 2 and VLAN 3 (readily available as dedicated ports, in VLAN and switch terms as access ports. How would you expect these VLAN are becoming available on the switch, and finally on the WAX? Have attempted to explain this briefly in my previous reply. but was ignored, probably because you found the VLAN 1 (default on the switch) seemed to work for you, so why bother?
- tchubabaSep 27, 2023Guide
Don't bother. Thanks mate.
If anyone else has any insights into this issue and would like to provide your feedback I'd highly appreciate it.
- ToniRodSep 28, 2023Guide
Hi,
We may be facing the same issue..
Detailed thead here: https://community.netgear.com/t5/Business-Wireless/WAX630E-VLAN-bug/m-p/2325009/highlight/true#M11089
I'm in discussion with Netgear support since late August trying to find a solution.
- tchubabaSep 28, 2023Guide
Thanks ToniRod . From reading your linked post, it seems to be exactly the same issue I am having. I've been working on this for the past week to no avail. Anything I try doesn't work. I've reached out to Netgear tech support but haven't heard from them yet.
You mention you've been in contact with Netgear support about this since late August. Would you mind sharing what is the current status of your support case? Have they acknowledged any issues with the AP?
