tchubaba
Sep 26, 2023Guide
Inter-VLAN routing issue only via Wi-Fi
Recently I purchased the AP WAX630E and switch MS108EUP for my network in order to be able to create VLANs and isolate certain types of devices in the network. I am using these two products along wit...
- Sep 29, 2023
Hi ToniRod . I heard back from Netgear support. They confirmed that the issue is indeed with the WAX630E AP - it does not support Inter-VLAN communications when the devices are connected to the same AP, and they have no plans to add support for it. Apparently the only use case supported for this AP for inter-VLAN wi-fi communications is to use 2 different APs, which kinda doesn't make much sense in my head, but OK I guess. At least now I have confirmation that the issue is indeed where I suspected it was and can move on from here.
ToniRod
Sep 28, 2023Guide
Hi,
We may be facing the same issue..
Detailed thead here: https://community.netgear.com/t5/Business-Wireless/WAX630E-VLAN-bug/m-p/2325009/highlight/true#M11089
I'm in discussion with Netgear support since late August trying to find a solution.
tchubaba
Sep 29, 2023Guide
- MrJoshWOct 17, 2023NETGEAR Employee Retired
Hello Everyone,
An update on this. As a poster pointed out it does appear to affect the WAX630E models. This does not affect the WAX610, WAX620, or WAX630 access points. Currently we are working on a fix. Once we do have a proposed fix I can relay an ETA on a release.
- hunkofmonkSep 05, 2025Aspirant
Hi, MrJoshW
Can you please check this for WAX615 this is not fixed still
