m_elias
Mar 10, 2018Aspirant
Intermittent WAC730 WDS Bridge performance
I have two WAC730 APs (firmware 3.8.3.0) running in stand alone mode with WDS Bridge mode enabled on the 5GHz radios. Router<--wired-->AP1<--WDS-->AP2 When I wirelessly connect to AP2, most of the ...
- Apr 14, 2018
Not much to update other than I switched back to my Unifi APs for a while and now recently tried the ProSafe units again. I factory reset the two WAC730s, deployed the WC7500 and provisioned the same two WAC730s. Using the controller is a much better experience. No waiting for APs to reboot after every configuration change etc.
m_elias
Mar 13, 2018Aspirant
The 2 WAC730 APs are sitting upright on tables, 30-40ft apart with LoS. There are some other wireless networks present but their signal is weak.
There is only light, mobile device browsing that I know of. I will try to save the logs sometime when I notice an issue.
RaghuHR
Mar 19, 2018NETGEAR Expert
- m_eliasApr 14, 2018Aspirant
