Myronm
Jun 24, 2017Aspirant
Invalid WPA Passphrase
I cannot connect my HP Laser Jet 475 printer to my Access Point. It shows the SSID but refuses to WPA Passphrase. I have made sure there were no spaces in the name and it still doesn/t work!
- Jun 24, 2017
Hi Myronm,
Welcome to our community!
Have you tried using other network authentication from your AP? You can isolate it by using WPA2-PSK or try connecting it to other wireless network.
Myronm
Jun 26, 2017Aspirant
I discovered that if i set the AP for WPA & WPA2-PSK, my printer connected right to it! Thanks!
JohnC_V
Jun 27, 2017NETGEAR Employee Retired
That's great! I encourage you to mark the appropriate reply as the “Accepted Solution” so others can be confident in benefiting from the solution. The NETGEAR Community looks forward to hearing from you and being a helpful resource in the future!
