AngryDog
Oct 16, 2017Guide
KRACK Vulnerabilities
Does the latest firmware fix any of the below vulnerabilities? CVE-2017-13077, 13078, 13079, 13080, 13081, 13082, 13084, 13086, 13087, 13088 If not, when will firmware be released to fix thes...
- Oct 25, 2017
Let me share this forum link:
Auri
Oct 16, 2017Star
Agreed - is a patch in the works? Hoping you won't ignore us.
FYI: I heard Microtik has a fix in their latest firmware.
For those of you who are unaware, below is a link to the vulnerability details. Basically, if you're using WPA2 encryption, which almost everyone is, you're vulnerable. Yowsa.
https://betanews.com/2017/10/16/krack-wpa2-security-vulnerability/
AngryDog
Oct 16, 2017Guide
Ubiquiti are also releasing a patch. I belive that they have one available on beta test. I've been trying to get my manager to move to Ubiquiti for a while, this could push us..
- AuriOct 16, 2017Star
I also added a note to their IdeaBoard:
Give it a thumb up and get their attention?
- AngryDogOct 16, 2017Guide
Done! This is serious and needs addressing ASAP.
My only query is, is that does a patched AP with an unpatched device (like a mobile phone / laptop) mean that it is secure?
From what I understand, as long as ONE device is patched, you're OK. It appears that the hack works by forging a copy of the Wi-Fi network, then getting the device onto the forged network. If the device doesn't require a certificate re-send on the hop to the new network, then it's vulnerable. I tweeted a link:
http://www.arubanetworks.com/assets/alert/ARUBA-PSA-2017-007_FAQ_Rev-1.pdf
Ideally, you want the client OS patched, and all routers as quickly as possible.
