AngryDog
Oct 16, 2017Guide
KRACK Vulnerabilities
Does the latest firmware fix any of the below vulnerabilities? CVE-2017-13077, 13078, 13079, 13080, 13081, 13082, 13084, 13086, 13087, 13088 If not, when will firmware be released to fix thes...
- Oct 25, 2017
Let me share this forum link:
AngryDog
Oct 16, 2017Guide
Yes that would make sense. The idea is though to make sure you're not on "their" network, and the only way of doing that currently is to effectively get patched, once patches are available.
The issue is, when are those patches going to be available? It has become an arms race.
RaghuHR
Oct 16, 2017NETGEAR Expert
WAC720/WAC730 - > firmware version 3.7.12.0 is having the fix.
- Fixed security vulnerabilities in WPA2 handshake mechanism.
Please refer the link below for more details.
https://kb.netgear.com/000049001/WAC720-WAC730-Firmware-Version-3-7-12-0
Thanks
Raghu
- AngryDogOct 16, 2017Guide
Thanks. I did see that but wasn't sure as it isn't very specific, and I like specifics!
Well that was fun. The firmware update broke the Access Point, thanks for that.
- AuriOct 16, 2017Star
Which firmware update? Haven't seen a new one come through yet.
It helps to scroll up. I'll try it today! Thanks!
Ahh, I see. I have an R8000 X6 Nighthawk consumer router. Will there be a firmware update coming for that product?
I wouldnt use it. Its broken the Access Point here. I am not amused.
- GaltOct 16, 2017Aspirant
When will a firmware patch to address the Krack WPA/WPA2 vulnerability be released for the Orbi RBK53 (RBR50)?
Thanks.
- slatedrakeOct 16, 2017Initiate
Second vote for patch for X6 AC32000 Nighthawk (R8000)
- RexPOct 23, 2017NETGEAR Expert
Which Access Point are you using? Which Firmware version did you download? Are you using a controller managed Acces Point or a Standalone Access point? Hope we can help you quickly.
- GaltOct 24, 2017Aspirant
Orbi RBK53 AC3000
Router: RBR50
Satellites (2): RBS50
Firmware Version installed: 2.0.0.74
- DaneAOct 25, 2017NETGEAR Employee Retired
