ksjnx
Dec 26, 2021Follower
Latency issue with WAX610
Hello, I am having an issue with latency on my WAX610. My setup is 3 SSID's with separate vlan tags. The SSID's are standard setups with the exception of the vlan tag. My WAX610 is connected to a...
DaneA
Dec 27, 2021NETGEAR Employee Retired
Welcome to the community! :)
Since you already tried to downgrade the firmware and perform a factory reset on your WAX610 but still the same problem, I suggest you to open a support ticket with NETGEAR Support here at anytime. In this way, a thorough hardware check on your WAX610 will be conducted by the NETGEAR Support Team.
DaneA
NETGEAR Community Team
