jpridx
Mar 19, 2019Tutor
Model WAC 104 (Access Point) can't access login page
Hello! I just purchased a Netgear WAC 104 Access Point unit, and it appears as though there's no website available to connect to in order to get this unit operating. I've tried http://www.aplogin.net...
- Mar 19, 2019
The problem has been resolved! It seems that Netgear has slipped a few notches in recent years. The installation manual was worthless.
jpridx
Mar 19, 2019Tutor
Mar 19, 2019Guru - Experienced User
The default IP maybe if you have a directly connection with a PC with out it being connected to a router. The APs IP address will be what ever is seen on the routers connected clients list that the WAP gets from the router.
- jpridxMar 20, 2019Tutor
Yeap, that's pretty much what happened. I was initially trying to set it up with a wireless laptop while using the supplied login page (aplogin.net) and the given IP address (192.168.0.100), and nothing seemed to work. Once I hooked up the WAC104 directily to the router through my desktop computer, it automatically assigned an IP address which enabled me to set up the unit. I'm not sure why I didn't see the assigned IP address previously, for it was hooked up directly to the router. Oh well. At any rate, it's working great now! Thanks!
- FURRYe38Mar 20, 2019Guru - Experienced User
Enjoy. :smileywink:
