centrespot
Dec 07, 2017Aspirant
multi access using prosafe ANT2409 antennas and WNAP320 access points
Hi All I am new to this help forum and was hoping someone can spare a little time guiding me in the right direction. I have a client that wants CCTV cameras fitted to two outbuildings and have the ...
- Dec 17, 2017
I apologize for the late response. I inquired your concern to the higher tier of NETGEAR Support about the ANT2409 if it will work to the WNAP320. I just got a feedback.
As per the higher tier of NETGEAR Support, the ANT2409 was released for an earlier family of ProSAFE Access Points (such as the WG302 & WG102). But in theory, it should work with the WNAP320 since it supports using an external antenna (option is in Advanced Wireless settings indicated in its reference manual here). Be reminded that you might be required to purchase an antenna cable.
DaneA
NETGEAR Community Team
DaneA
Dec 17, 2017NETGEAR Employee Retired
DaneA
DaneA
Dec 20, 2017NETGEAR Employee Retired
I just want to follow-up on this. Let us know if you have further questions.
Otherwise, if ever your concern has been addressed or resolved, I encourage you to mark the appropriate reply as the “Accepted Solution” so others can be confident in benefiting from the solution. The NETGEAR Community looks forward to hearing from you and being a helpful resource in the future!
DaneA
