Hounddawg
Jul 10, 2017Aspirant
Need instructions to update WFS709TP firmware.
I have a WFS709TP smart wireless switch and some maching WAGL102 Access Points that I'm reconfiguring for use in a Restaurant/Sports Bar/Entertainment Centre for use by guests. Before I configure th...
DaneA
Jul 11, 2017NETGEAR Employee Retired
You're welcome! :) Keep us posted if you're able to update the firmware of your WFS709TP to the latest version.
DaneA
NETGEAR Community Team
DaneA
Jul 16, 2017NETGEAR Employee Retired
I just want to follow-up. Were you able to update the firmware of your WFS709TP to the latest version?
DaneA
- HounddawgJul 16, 2017Aspirant
Yes. I was able to update it, but couldn't do it from within Windows. I ended up installing a TFTP server on my computer and updated it through TFTP. No problem after that.
Thanks again,
Tom
- DaneAJul 17, 2017NETGEAR Employee Retired
Thanks for the feedback. I'm glad to that you were able to update the firmware of the WFS709TP via TFTP. :)
Since your concern has been resolved, I encourage you to mark the appropriate reply as the “Accepted Solution” so others can be confident in benefiting from the solution. The NETGEAR Community looks forward to hearing from you and being a helpful resource in the future!
Cheers,DaneA
