ugonzalezh31
Jan 09, 2024Aspirant
Neighbor AP feature and Mesh
Hi I have fully read the user manual of the Wax610Y and Wax620 but there is no mention on what is the usage of the "Neighbor AP" feature (configuration/security/neighbor AP menu option) Wh...
- Jan 12, 2024
Not available in the standalone management - Insight features only:
- Basic roaming and OKC roaming can be enabled by location.
- 802.11r can be enabled by SSID on the Wireless Settings
ugonzalezh31
Jan 12, 2024Aspirant
schumaku
Searching in the documentation I do not see any mention to 802.11r or Mobility ID
https://www.downloads.netgear.com/files/GDC/WAX620/WAX620_UM_EN.pdf
I also searched on the GUI of the device and came back empty hands, I had to be honest I do knew about 802.11r but no idea on the mobility ID. So .. are these features that are not accessible from the GUI and get enabled only when you join Insight ??
schumaku
Jan 12, 2024Guru - Experienced User
