VIRTUALWORLD
Jun 24, 2025Aspirant
Netgear Access Point for Handling RSSI and CSI
I am trying to develop a system using some Access Points that support the following functions. Please let me know if there is a Netgear Access Point that supports the following functions. It would ...
Jun 25, 2025Guru - Experienced User
so you've already narrowed your list by "must be possible by installing openwrt".
Check their supported device list and pick something from that.
