kmsri
Jun 07, 2016Aspirant
Netgear Prosafe Router Model SRXN3205
I bought this router couple of years back and never used it. Started using it few days back when my old linkys router went of order. Initially, the router was working well for couple of days - af...
- Jun 08, 2016
Thank You Dane.. The problem is resolved and the router is working now.
Appreciate taking time to do this for me
Regards
Sri Margan
kmsri
Hi Dane, Thank You for volunteering to help me. Answers to your questions
a. Yes
b. Modem only Device
c. Not sure what it is - I tried to login to device interface to find it - it says I am blocked to login ( this happened just now - earlier during the day, I was able to login)
d. Yes I did - but same issues
Kindly see what best you can do to resolve the issue
Thanks again
Sri Margan
DaneA
Jun 07, 2016NETGEAR Employee Retired
Hi kmsri,
Since you are unable to login to the web-GUI of the SRXN3205, try the following below:
a. Use other browsers like Firefox or Safari.
b. Clear the cache of the browser.
c. Use other PC or laptop to login to the web-GUI of the SRXN3205.
DaneA
NETGEAR Community Team
