skipmesh
Nov 10, 2023Aspirant
Netgear WAC120 - Maintenance Menu Missing after Firmware v2.0.5 update
As the title says. I went to upgrade my firmware to the latest version. As per instructions I upgraded first to v2.0.5 (maybe I already had - there didn't seem to be any way to know what firmware ver...
schumaku
Nov 10, 2023Guru - Experienced User
When looking into the WAC120 https://www.netgear.com/support/product/wac120#download section, we find the current firmware version is WAC120 Firmware Version 2.1.7 since the year 2018. These release notes unveil a requirement to install 2.0.5 before updating further.
Formally, the firmware version is available under Monitoring -> System
Reads like this older firmware in place has some interop issues with the modern browsers
Have already tried to reset and drop your unknown Web browser cache?
- skipmeshNov 10, 2023Aspirant
Thanks. Yes I reset it. The issue is there is ONLY the Configuration tab after installing the required firmware.
Thanks for trying to help. I'm binning it and getting something more recent.
- schumakuNov 13, 2023Guru - Experienced User
To continue operating your legacy WAC, give modern Edge a try and enable Internet Explorer mode in Microsoft Edge
