skipmesh
Nov 10, 2023Aspirant
Netgear WAC120 - Maintenance Menu Missing after Firmware v2.0.5 update
As the title says. I went to upgrade my firmware to the latest version. As per instructions I upgraded first to v2.0.5 (maybe I already had - there didn't seem to be any way to know what firmware ver...
skipmesh
Thanks. Yes I reset it. The issue is there is ONLY the Configuration tab after installing the required firmware.
Thanks for trying to help. I'm binning it and getting something more recent.
schumaku
Nov 13, 2023Guru - Experienced User
To continue operating your legacy WAC, give modern Edge a try and enable Internet Explorer mode in Microsoft Edge
