gwichman
Jul 16, 2016Aspirant
Netgear WAC120 Wireless slow
we purchased a wac120 over a year ago and its been a frustrating experience. i've had nothing but issues with the wifi.. it used to be that it'd start out up around 70-80Mbps which was obviously grea...
- Mar 06, 2017
Hi all
We have patch image ready for this wilreless slow on 5 Ghz radio. Please reach https://www.netgear.com/support/contact.aspx to get the patch image
Thanks
Raghu
saschapil
Jan 10, 2017Aspirant
Hi,
I was wondering if there is any progress on this matter?
Or should I just bin my wac120's and buy something else?
Getting a bit tired of finding lots of posts/forums with the same problems but no solutions whatsoever..
Sascha
rraju
Hi Sascha,
Don't bin them. I heard netgear team is working on this seriously. We will get an update soon. Meanwhile just add a script reboot the AP at midnight automatically. I can send the script to you if you need.
- benterJan 11, 2017Aspirant
Just joined the forum to chip in and say I have exactly the same issue. WAC120 on fw 2.07 and experience extreme slowdown on a number of devices over the course of a few days. Rebooting sorts it for another few days. Extremely frustrating and I'm considering buying something else...
A reboot script would be handy.
- rrajuJan 12, 2017Aspirant
Hi,
I shall come with a script that will do something better than a total reboot at midnight. Busy right now. Will come up with something by mid next week. This should work until netgear comes up with a serious fix.
I will publish it once I get it tested.
- DaneAJan 23, 2017NETGEAR Employee Retired
benter / gwichman / saschapil / Paul2004v / raven99 / rraju,
I just got an update that a fix for this issue will be released as a new maintenance firmware for the WAC120 . Its scheduled to be released in the 2nd quarter of 2017.
DaneA
NETGEAR Community Team
