TheGuru47
May 26, 2025Aspirant
NETGEAR WAX610 Dual-Band WiFi 6 Access Point
Hi. I want to create a local network that allows my devices to communicate directly with each other without having an internet connection. This way, I can use a master/slave app during band rehearsa...
May 27, 2025Guru - Experienced User
I should have read a little more carefully. totally space cadeted its an access point without a router function. I tend to play more on the consumer side where its router first with an access point mode. Not access point with "maybe" a router mode .
Got an old router sitting around and not an access point that you could try it with?
