TheGuru47
May 26, 2025Aspirant
NETGEAR WAX610 Dual-Band WiFi 6 Access Point
Hi. I want to create a local network that allows my devices to communicate directly with each other without having an internet connection. This way, I can use a master/slave app during band rehearsa...
TheGuru47
May 28, 2025Aspirant
I’m under the impression that setting up the wireless access point (and devices that will connect) using static ip addresses will allow me to accomplish what I want … to use the wireless access point as a stand-alone device that will allow on-stage iPads to communicate with one another. Does that make sense if the only thing throwing a router into the mix would do is assign ip addresses?
