APD
Oct 18, 2024Aspirant
Outdoor coverage with Orbi RBS760
I've just installed an Orbi RBS760 system in my house with 4 satellites. I want to get wifi in my back garden but am not sure what product to add. It looks like the WAX610Y is Netgear's only o...
CrimpOn
Oct 18, 2024Guru - Experienced User
Until about 2015, WiFi Extenders were routinely used to extend WiFi coverage over a wider area. The main drawback to extenders was that WiFi devices did not roam seamlessly between units. Users would find that performance suffered as a mobile device stayed connected to a WiFi access point that was farther away than a nearby unit. People had to realize, "oh, crap" I need to restart the WiFi on my tablet (phone, laptop, etc.) Mesh systems were created by Google, Netgear, TP-Link, etc. to address this problem. The result: seamless roaming.
So, if the goal is to provide WiFi to devices which remain in fixed locations, WiFi extenders (from any vendor) are fine.
One potential solution is to locate indoor satellites next to outside walls (or even in windows which do not have metallic film) so that half of their signal "goes outside". With four existing satellites, there may be significant outdoor coverage already (depending on the construction of exterior walls). The problems with locating indoor satellites outside include (a) getting electrical power to them, (b) sheltering them from weather and extreme temperatures, and (c) getting the WiFi connection to them. Outdoor rated WiFi extenders address these issues mostly by using Power over Ethernet (PoE) to provide both the power and signal. Low voltage Ethernet cable is relatively easy to pass through exterior walls.
No one knows why Netgear did not produce a WiFi6 version of the RBS50Y outdoor rated satellite. (Perhaps they didn't sell enough to justify the cost?) There is no obvious benefit from purchasing an outdoor rated WiFi extender from Netgear.
- APDOct 18, 2024Aspirant
Thank you for the advice. It was really helpful. Previously, I had no wifi signal more than 15 feet into the garden. I have now positioned one of the satellites to the back of the house, on an upstairs bedroom window ledge (inside). It is wirelessly connected. It has improved the signal in the garden but just "okay". The router is downstairs at the front of the house (can't move it) and the other 3 satellites are hard wired.
1 satellite is in the attic (hard wired)
1 satellite in a cupboard below the television (hard wired)
1 satellite in the kitchen suspended ceiling (hard wired)
Bit of a theme. All the satellites are "covered" or "enclosed" in some way. Would that have a significanlty negative impact?
Thanks again,
APD
