ymmengin
Aug 31, 2015Aspirant
Problems with 3.0.0.7 Firmware and WNDAP350
After upgrading 2 different WNDAP350 from 2.1.9 to 3.0.0.7 I had some strange behaviors in the management interface… Depending on the browser I used (IE11, Chrome and Firefox) the visible menus would...
- Sep 05, 2015
Hi ymmengin,
Thank you for your feedback. Unfortunately, you cannot load the configuration file from an older Firmware version 2.x on your AP that runs the Firmware 3.x. I am pretty positive that this new Firmware 3.x will work fine in standalone or cloud (BCWM) mode.
Kind regards,
BrianL
NETGEAR Community
ymmengin
Hi BrianL,
I had gone over the documentation and agree that per release notes the WNDAP350 can be downgraded to 2.1.9. Unfortunately it doesn't say how. The BCWM can't do anything besides push or inform you about new firmware; nothing about reverting.
When I select the standalone mode the AP GUI doesn't show any menus to configure or change firmware. I have the same menus after switching from BCWM mode (Cloud Enabled) to standalone!!!
If anyone could help on how to revert back to prior firmware or how to get back to the standalone mode?
Also how do I post attachments (jpeg) ?
Thanks.
BrianL2
Aug 31, 2015NETGEAR Employee Retired
Hi ymmengin,
You can insert the screenshots by clicking the "Insert/Edit image". Ensure the images are in .png format. Regarding this issue that you reported, I am closely working with our Engineers and waiting for their feedback.
Kind regards,
BrianL
NETGEAR Community
