ymmengin
Aug 31, 2015Aspirant
Problems with 3.0.0.7 Firmware and WNDAP350
After upgrading 2 different WNDAP350 from 2.1.9 to 3.0.0.7 I had some strange behaviors in the management interface… Depending on the browser I used (IE11, Chrome and Firefox) the visible menus would...
- Sep 05, 2015
Hi ymmengin,
Thank you for your feedback. Unfortunately, you cannot load the configuration file from an older Firmware version 2.x on your AP that runs the Firmware 3.x. I am pretty positive that this new Firmware 3.x will work fine in standalone or cloud (BCWM) mode.
Kind regards,
BrianL
NETGEAR Community
ymmengin
Sep 03, 2015Aspirant
Hi BrianL,
That procedure worked. I now have the menus back and had to reconfigure manually... but that was not too bad as I had taken screeshots prior to the firmware upgrade. I couldn't restore with the saved config I had.
Now I'll give 3.0.07 a shot and see what happens.
Thanks,
YM
BrianL2
Sep 05, 2015NETGEAR Employee Retired
Hi ymmengin,
Kind regards,
BrianL
NETGEAR Community
