sparky2811's avatar
sparky2811
Prosafe WC7520 controller firmware upgrade question
Dear all   I'm completely new here so bear with me.  :)   I am an IT technician at a small primary school.  I’m fairly new to the job and trying to figure out how the Netgear system works.   We...
  • DaneA's avatar
    DaneA
    Sep 18, 2017
    sparky2811,
    You may use partition 2 since its the current active partition and proceed with the firmware upgrade.
    There is no option to check what is the current firmware version on partition 1 unless, it is activated.  For me, I suggest not to activate partition 1 yet because we do not know the current firmware version stored in it.  It might be a lower version of the firmware or it could be there is no firmware version stored in it. However, we could select partition 1 to which the new firmware to be saved then activate it.
    DaneA
    NETGEAR Community Team
ProSupport for Business
