jkenny1408
Jan 11, 2022Follower
Question regarding multiple WAX620 Access Points
I have a question regarding the WAX620 Dual Band Router. We have an office with Wifi setup using Ubiquiti access points. We have 4 Ap's setup. In the setup for the Unifi all the AP's are controlle...
- Jan 11, 2022
Yes, Insight does allow a single point of management for multiple WAX6xx (or WAC5xx). the SSID by location or for the complete organisation can be defined once, adding more APs is a snap, changing keys and so on is applied to all APs, and you get with a minimum of effort the seamless roaming you rare behind, too.
schumaku
Jan 11, 2022Guru - Experienced User
