festus4711's avatar
festus4711
M4300 - Question regarding place were the stack config is stored?
Hello Community,
I am using multiple stacks of M4300.
However, I have problems with the stack at one customer.
Maybe something was missed during the setup and so I booted the mini stack from two 8x8 switches with factory-defaults. My normal config was deleted, but there was still the config around the stack!
In which file is the stack config stored and with which CLI command can I really delete everything?
Thanks in advance
Dirk
  • LaurentMa's avatar
    LaurentMa
    Jul 30, 2020
    Hi, yes stacking configuration is stored at a different place. Please find these how-to's, you can use the general command, or delete stacking configuration manually. Below is CLI, but obviously you can follow the manual method in the GUI as well.
    HOW TO TOTALLY CLEAR STACK CONFIG FROM ONE SWITCH:
    - POWER DOWN THE SWITCH WE WANT TO REMOVE FROM THE STACK
    - DISCONNECT THE STACKING CABLES COMING TO AND/OR STARTING FROM THAT SWITCH
    - RESTART THIS SWITCH SEPARATE, IN STANDALONE MODE
    - LOG INTO THE CONSOLE
    - ISSUE FOLLOWING COMMANDS:
    User:admin
    Password:
    (M4300-8X8F) >en
    (M4300-8X8F) #config
    (M4300-8X8F) (Config)#switch 1 priority 1
    (M4300-8X8F) (Config)#exit
    (M4300-8X8F) #write memory
    (M4300-8X8F) #erase stack-config
    -->it reboots. After reboot, the switch is standalone.
    Optional: Clear the configuration
    User:admin
    Password:
    (M4300-8X8F) >en
    (M4300-8X8F) #clear config
    (M4300-8X8F) #reload
    Are you sure you want to reload the stack? (y/n) y
    MANUAL Method
    Manually if switch 2 disconnected from the 3-switch stack:
    (M4300-8X8F) (Config)#stack
    (M4300-8X8F) (Config-stack)#no member 1
    (M4300-8X8F) (Config-stack)#no member 3
    (M4300-8X8F) (Config-stack)#stack-port 2/0/9 ethernet
    (M4300-8X8F) (Config-stack)#stack-port 2/0/10 ethernet
    (M4300-8X8F) (Config-stack)#exit
    (M4300-8X8F) (Config)#switch 2 renumber 1 but it requires reboot......
    I hope this will help, please let us know how it goes!
  • DaneA's avatar
    DaneA
    NETGEAR Employee Retired
    festus4711,
    You may use the clear config command in Privileged EXEC Mode to reset the switch configuration to its factory default settings without powering off the switch.  As reference. kindly read page 240 of the M4300 CLI Reference Manual here.
    DaneA
    NETGEAR Community Team
    • festus4711's avatar
      festus4711
      Hi DaneA,
      thank you for the provided CLI reference guide.
      Unfortunately the CLI command "clear config" again only deleted the standard configuration, like VLANs, Port-description, etc. Furthermore all settings around STACKING are still available! The previously configured stacking ports are still there, but also the priorities of the stack members. It must be somehow possible to delete everything?
      I am glad for all tips.
      Thanks and greetings in advance
      festus4711
        LaurentMa
        NETGEAR Expert
        User:admin
        Password:
        (M4300-8X8F) >en
        User:admin
        Password:
        (M4300-8X8F) >en
        MANUAL Method
ProSupport for Business
