jameslast
Oct 25, 2016Aspirant
Add WNAP210 v2's to Business Central
 Hello All,     a few months ago I purchased 3 WNAP210 's, and 2 days ago I created a Busines Central 90 day  free trial account.  I would like to add the access points to " the cloud". So far no luck...
- Oct 26, 2016
Hi jameslast
Can you please check the firmware version on the AP? Latest is 3.5.20.0. Please upgrade to this and try.
http://kb.netgear.com/app/answers/detail/a_id/31400
Refer the upgrade table before initiating firmware upgrade.
Thanks
Raghu
RaghuHR
Oct 26, 2016NETGEAR Expert
Hi jameslast
Thanks
Raghu
jameslast
Oct 26, 2016Aspirant
Hello Raghu,
thanks for the reply.
Yes, the firmware upgrade solved the issue.
Many thanks!
Greetings, J
