GordnFreeman
Mar 12, 2018Aspirant
[Bug] Daylight Saving time Implementation
Model: WAC730 ProSAFE Dual Band Wireless AC Access Point Firmware: 3.7.11.0 Appearently the offset of the Daylight saving time is not always adjusted correctly regarding specific timezone differ...
- Mar 13, 2018
Hi GordnFreeman,
Welcome to the community! :)
I suggest you to upgrade the firmware of your WAC730 to the latest version which is v3.8.3.0. One of the fixes include showing proper time based on time zone configured during DST period. You can download firmware v3.8.3.0 here.
Be reminded to perform a factory reset to your WAC730 after upgrading the firmware then reconfigure the settings from scratch in order to start clean using the latest firmware version. Observe if same problem will occur.
DaneANETGEAR Community Team
DaneA
Mar 18, 2018NETGEAR Employee Retired
I just want to follow-up on this. We’d greatly appreciate hearing your feedback letting us know if the information I’ve provided has helped resolve your concern or if you need further assistance.
If ever your concern has been addressed or resolved, I encourage you to mark the appropriate reply as the “Accepted Solution” so others can be confident in benefiting from the solution. The NETGEAR Community looks forward to hearing from you and being a helpful resource in the future!
DaneA
GordnFreeman
Mar 18, 2018Aspirant
Hello DaneA,
I'm sorry I'm currently in a have congested time bottleneck and had not the time nor the attention to do anything more than recognize that the bug probably has been fixed already, and that I shamefully did not check for the latest firmware first^^...
So I can't say if it worked, I believe it does - if the bug has been fixed xD
Probably I will notice on the winter-time switch or next year :-)
thnx!
Best Regards GordnFreeman
