bartosz-l's avatar
bartosz-l
re-discover managed access point
Good afternoon,
controller: 7600
access point: WAC720
Access point was no longer used, disconnected from network, and removed from managed access points list.
Now I need it back to work with the system.
But Wizard and running discovery is not detecting this access point.
1. What is the procedure to add this access point back to list?
2. Do I need to restore AP standalone firmware first, and then discover it using controller?
regards
Bartosz
  • JohnC_V's avatar
    JohnC_V
    NETGEAR Employee Retired
    bartosz-l,
    If it is the same wireless controller, you don't need to re-install the standalone firmware but it will depend if the AP is running on the same firmware as the controller. if you are not sure about the installed firmware then It would be best to install a standalone firmware and discover it using the controller.
    John
    NETGEAR Community Team
    • bartosz-l's avatar
      bartosz-l
      thank You for Your reply.
      So, assuming it is same firmware:
      When I remove (configured and working) access point from 'managed AP list' then I should be able to re-discover this AP again if I use Discovery wizard?
      regards
      • JohnC_V's avatar
        JohnC_V
        bartosz-l,
        That is correct. Just use the discovery wizard from your controller and you may be able to detect the access point. Just let me know if that will not work.
        John
ProSupport for Business
