rockit1967
Nov 29, 2016Aspirant
May I turn DHCP off?
I have WAC120 plugged into the router supplied with my ISP via one of LAN ports. May (should) I turn DHCP on WAC120 OFF if it's also turned ON on the router?
- Nov 29, 2016
Hi rockit1967
You dont need to enable DHCP server on WAC120 if you are already running DHCP server on router supplied by ISP. This should give IP address to all your wireless clients connecting to WAC120. Hope this helps.
https://kb.netgear.com/app/answers/detail/a_id/31208?cid=wmt_netgear_organic
Thanks
Raghu
RaghuHR
Nov 29, 2016NETGEAR Expert
Hi rockit1967
Thanks
Raghu
rockit1967
Thank you, Raghu
