NickC44
Dec 20, 2016Aspirant
mib troubles
I am trying to find out the rssi and bssi of a WNAP320, but cannot seem to get my network monitor app (Intermapper) to recognize the particular OID. I have loaded the correct mib file, and can pull ...
- Jan 02, 2017
Hi Nick
Hope there is no obstacles or any interferences betweek two buildings. You can use third party application such as inssider to find out signal strength. .
http://www.metageek.com/products/inssider/
Regret to inform you that Our current firmware do not support remote AP signal strength in WDS mode.
Thanks
Raghu
RaghuHR
Jan 02, 2017NETGEAR Expert
Hi Nick
Thanks
Raghu
NickC44
Jan 02, 2017Aspirant
Okay, thanks Raghu. I appreciate you help with this issue.
Nick
