HarmonHodge
Apr 21, 2023Star
Outdoor access point
I am looking to provide better wifi on my deck. I have a wired network from a ATT Remote Gateway (1 Gig) to a Netgear unmanaged switch. I have CAT 6 to an LG TV, Netgear WAX 620 and a couple of jacks...
- Apr 21, 2023
HarmonHodge wrote:
I am looking to run CAT 6 to my deck. Does Netgear make a small access point I can plug into the wall outside (under the eaves and GFCI outlet) and connect to CAT 6?
Alternate to an expensive power installation with GFCI, connector boxes and space for huge power bricks, consider a PoE+ or PoE++ wireless access point on a CAT6 or better cabling.
Cumbersome is that enclosures for wireless AP are not inexpensive.
Apr 24, 2023Guru - Experienced User
POE switches are a bit spending. If thats your only POE device, a poe injector might be a better purchase.
HarmonHodge
Apr 26, 2023Star
I picked up an injector. It took a little bit on the NetGear side but it os working now. I picked up a 60W BV-Tech. I was looking for a NetGear Injector but did not see one. I will return the unopened 16 port POE switch to Amazon. $40 vs $200. Thank you for the information. I came close to sending the injector back but my current switch is less than six months old.
Harmon
