SiriusDoggy's avatar
SiriusDoggy
Initiate
Nov 25, 2023
Access point or Range extender confusion
Here's my situation. I have a home that also has a small casita out back that I use as my office. In my home I have  Nighthawk RAX50 router that my cable modem is attached to. WiFi works fine throughout my home but it doesn't reach the casita. I do happen to have a CAT6e line running from my router to the casita and it is plugged directly into my desktop PC which works great since it is hardwired. But that still leaves me with no WiFi in the casita.
I want to keep my office PC hardwired but I also want to have wireless in the office for my phone/tablet and guests.
I'm confused about what I need, an access point or range extender?
Ideally I would plug the one CAT6e line into a "box" that then gives me a hardwired output to my PC and potentially other hardwired devices and WiFi in the rest of the office. I want the WiFi to be the same so when I walk from the office to the house it stays on the same network.
Thanks for the advice.
  • plemans's avatar
    Nov 26, 2023
    Yes you can still use the hardwired in connections.
    AP mode just disables the router functions that manage data inspection/routing. It leaves the primary router managing all that.
    I use AP mode all the time as I test different systems.
    Some pretty solid deals out there this weekend for picking up routers 🙂
  • plemans's avatar
    either would work. Most extenders have an access point mode (not all).
    And most routers have either router or access point mode.
    So either would work.
    If it was me? I'd pick up a renewed router off amazon and use it in access point mode.
    Then if you're primary dies, you have a backup router you can swap in.
    • SiriusDoggy's avatar
      SiriusDoggy
      Initiate
      Thanks for the quick response and helpful answer.
      I see in my router setup that I can turn my RAX50 into AP mode. Maybe I'll get a newer router for the home and move the RAX50 to the office.
      The one thing I'm still a bit confused about in reading about the differences between Range Extenders and Access Points is this.
      If I move the RAX50 to the office and set it up as an Access Point with a new router in the home, will I still be able to use the RAX50 as a hardline device too for my desktop, printer and IP camera?
      • plemans's avatar
