dhda
May 23, 2022Aspirant
WAX610 needs reboot daily, before clients can connect
Approaching the WAX610 AP, WIFI Analyzer shows the strong signal (-40dB) but Android as well as Windows clients do not connect, not even after switching OFF/ON WIFI. They remain on an AP, too far aw...
RaghuHR
May 25, 2022NETGEAR Expert
Hi dhda
I think you are roaming between two APs...P IP ...101 to AP IP ...249 Could you please provide the detailed logs of both the APs? AP IP ...101 and AP IP ...249?
Thanks,
Raghu
dhda
May 25, 2022Aspirant
Just realised, the logging of the other AP (IP 101) covers the whole period, cause it hasn't been rebooted since the morning.
This means the test around 12:45, trying to connect, moving from 101 to 249 is in the log, as well as the test and the reboot of 249 later on, after which everything connected to it.
Link to the log of 101 : https://1drv.ms/u/s!Ai4PEQfZRtEfgpBdw2aFW_R60PkPcg?e=wOqrp1
In the meanwhile, AP with IP 101 seems getting IP 154.
Best Regards (and enjoy the long weekend ?)
- dhdaMay 31, 2022Aspirant
May I ask if the latest log maybe could clarify a little more ?
In the meanwhile, there was one day the AP didn't has to be rebooted (!?), but all other times, number of clients remained 0 (according to insight and also the weak connection on the client), untill the AP had been rebooted.
Thanks in advance.
- RaghuHRMay 31, 2022NETGEAR Expert
Hi dhda
Could you please share me the logs of both APs at the of the issue?That will really help us to pin point where the issue is. We have the logs from one of the APs,
Thanks,
Raghu
Hi Raghu,
Thanks for the very fast response.
https://1drv.ms/u/s!Ai4PEQfZRtEfgpBdw2aFW_R60PkPcg?e=wOqrp1 should have been the log of the other AP, from the same day as the other logfiles ?
Best Regards
