dhda
May 23, 2022Aspirant
WAX610 needs reboot daily, before clients can connect
Approaching the WAX610 AP, WIFI Analyzer shows the strong signal (-40dB) but Android as well as Windows clients do not connect, not even after switching OFF/ON WIFI. They remain on an AP, too far aw...
RaghuHR
Jun 02, 2022NETGEAR Expert
Hi dhda
While checking the logs that you sent you have taken the logs on may 26th with other AP and and previous logs shared with may 25th. Because of this date mis match we can not find any clue. Could you please send the both APs logs at the time of the issue so that we can match with timestamps?
Thanks,
Raghu
dhda
Jun 02, 2022Aspirant
I apologize, Raghu,
Since the other AP kept running, thought same time would still have been available in the logfile from may 26th but it seems limited in length.
Hope to get back to you soon, with fresh logfiles before reboot AP1/after reboot AP1/same period before and after reboot of AP2.
Best Regards,
Danny
- dhdaJun 02, 2022Aspirant
Hi again Raghu,
Here's a link to a folder containing logfiles from AP.249 and AP.154 before rebooted AP.249 and the logfiles again afterwards.
There's a ReadMe.txt where the actions in time can be found.
Rebooted AP.249 around 16:21, mobile testequip was Android Phone MA 56:00:58 IP .101.
https://1drv.ms/u/s!Ai4PEQfZRtEfgpBgkgYJHFFuzhYpOQ?e=qjnkgy
PS. While finishing all this, 56:00:58 still remains at the poor AP.249, also after WiFi OFF/ON, although AP.154 is next to the phone.
So added the logs of both AP's once more.
Hope you can retrieve the logfiles in the shared folder.
I'm curious now...
Goodluck and thanks in advance.
Best Regards,
Danny
- dhdaJun 05, 2022Aspirant
Hi Raghu,
Just wanted to listen if anything could be derived from the latest logfiles.
As everyday, today again the AP remained at 0 clients until rebooted and soon after the reboot, noticed 7 clients...
Best Regards,
Danny
