jasondunn
Jul 24, 2023Apprentice
WAX620PA 10.5.0.14 firmware update weakens 2.4Ghz network?
I installed firmware 10.5.0.14 on two WAX620PA's this weekend, and I immediately saw a reduction in network broadcast strength on the 2.4Ghz band. A printer that was previously connected was suddenly...
jasondunn
Jul 28, 2023Apprentice
Thanks David. Unfortunately for me, I do not pay the premium subscription fee so don't have the Insights Cloud portal access; I only have a few APs that I manage, so I do so from within the Android app. I haven't been able to find these settings in there so far; I've only been able to adjust the power from Auto to Full.
DavidGo
Jul 31, 2023NETGEAR Expert
Hi jasondunn
For now the workaround is to disable just the 802.11r setting, which is available on each SSID. To disable it via the Android app:
1. Go to the Locations icon in the menu at the bottom of the App.
2. Tap WiFi.
3. Your SSID(s) will load. Tap into an SSID.
4. Scroll right to the bottom, under Radio Settings you will see Fast roaming (802.11r). Tap the slider to disable it. (it is disabled when slider is grey).
5. Click Save.
As the setting is per SSID, if you have multiple Locations with multiple SSID's, you will need to repeat the steps to disable 802.11r on each SSID in each Location.
Thanks
David
