Bobiskey's avatar
Bobiskey
WAX630 Guest WiFI setup
So, first off, I am coming at this from the Meraki and Sophos back ground. So bear with me 🙂   In either Sophos or Meraki you could setup guest wifi on a separate ip range that would then be NATed...
ProSupport for Business
