MediaRenegades
Jun 19, 2022Tutor
WAX630 WiFi Performance Slow
Wax630 Wifi Performance is considerably slow. Max speed ~300Mbps MAX on a 1Gig connection. I have tried updating firmware, downgrading firmware, 20mhz, 40mhz, 80mhz, wpa2, wpa3, turning off o...
schumaku
Jun 20, 2022Guru - Experienced User
The newer S22 can do HX80, certainly the higher end plus and ultra (names from wally brain) are certainly AX systems3, capable for HT160. lLink rates look correct in the 800 mb/s range for both the AC notebook as well as the AX mobile. Keep in mind this is WiFi, not Ethernet, so the throughput can never reach the link rate. however, some 450...550 mb/s should be feasible.
*Very unlikely mobiles are anything different than 2x2 - by far to much power required (and by far to expensive).
RaghuHR please assist your customer
RaghuHR
Jun 20, 2022NETGEAR Expert
Hi MediaRenegades We need to see what is the configuration and logs. Is there anyway you can do the air packet capture?
Please download the detailed logs from the monitoring page and send it for us via PM? You can use cloud storage tool to upload the detailed logs.
Thanks,
Raghu.
