plfirre
Oct 13, 2015Aspirant
Wifi network solution for 200 users?
Hi everyone,
I’m looking for answer about a network infrastructure that can support our mobile application.
We would like to offer to our costumers a simple and removable network infrastr...
- Oct 14, 2015
Hi plfirre,
plfirre wrote:
In stand-alone mode, does the WNDAP660 has a DHCP server ? Can't find the information in the data sheets.
An Optional DHCPv4 Server can be configured on the WNDAP660 access point. Kindly check page 27 of the WNDAP660 reference manual here.
plfirre wrote:
What about 2 WNDAP660 access point connected to a ProSafe VPN Firewall with a DHCP server and so on?
The firewall won't give me a PoE, but beside that, can it work?
It will still work.
DaneA
NETGEAR Community Team
DaneA
Oct 14, 2015NETGEAR Employee Retired
Hi plfirre,
The WNDAP660 Wireless-N Dual Band Access Point seems to fit your requirements. As per page 29 of this link, it says that it supports 256 concurrent clients when the WNDAP660 is used as standalone access point. QoS can be configured as well. Kindly check these links below for more information:
http://kb.netgear.se/app/answers/detail/a_id/21571/~/wndap660-faqs
http://www.netgear.com/business/products/wireless/business-wireless/wndap660.aspx#tab-features
http://support.netgear.com/product/wndap660
Welcome to the community! :smileyhappy:
DaneA
plfirre
Oct 14, 2015Aspirant
Hi DaneA,
Thanks for your respond.
I'm a bit septical about just one AP for 200 users, but well.
In stand-alone mode, does the WNDA660 has a DHCP server ? Can't find the information in the data sheets.
What about 2 WNDA660 Access point connected to a ProSafe VPN Firewall with a DHCP server and so on ?
The firewall won't give me a PoE, but beside that, can it works ?
Thanks again,
Pierre-Louis.
- DaneAOct 14, 2015NETGEAR Employee Retired
Hi plfirre,
It will still work.
DaneA
