gregpearce's avatar
gregpearce
WNDAP330 Central Management (Device or Cloud)
Hi, First question I have posted here and apologise if already answered. Can anyone tell me if there is a device or cloud option with Netgear that will allow me to manage WNDAP330 devices? We have...
  • DaneA's avatar
    Aug 06, 2019
    @gregpearce,
    Welcome to the community! Smiley Happy
    I'm afraid to inform you that there is no compatible NETGEAR wireless controller for the WNDAP330.  Even the Business Central 2.0 is not compatible with the WNDAP330.  As reference, kindly check page 1 of the article here.
    Also, be reminded that the WNDAP330 has been EoL (End-of-Life) years ago.
    You may want to upgrade your WNDAP330 to either of these Insight Managed Access Points which are: WAC505, WAC510 and WAC540.  NETGEAR Insight is a Cloud-based management platform that enables easy setup and configuration of NETGEAR Insight Managed Access Points, Switches and ReadyNAS devices.  To know more about Insight and the Insight Managed Access Points, kindly access the links below:
    Insight Managed Smart Cloud Wireless Access Points
    NETGEAR Insight
    About the Insight subscriptions, I recommend you to the Insight Premium Subscription.  One of its benefits is the Fast Roaming.  Fast Roaming makes it easy for devices that are connected to any Insight Managed access point on your network to roam to any other Insight Managed access point on your network. Check the link below:
    What Insight subscription plans are available?
    DaneA
    NETGEAR Community Team
ProSupport for Business
