esaym
Dec 22, 2016Aspirant
WNDAP660 Connectivity Issues
I'll try to keep this story as short as possible. I run a small office and about two years ago I upgraded an older netgear G only access point to a newer WN203. All was well for about a year. Then I...
- Apr 20, 2017
So since the firmware upgrade and a factory reset this has been working.
DaneA
Dec 29, 2016NETGEAR Employee Retired
Can you provide the configuration file of your WNDAP660? You may provide me a download link for it.
DaneA
NETGEAR Community Team
esaym
Dec 29, 2016Aspirant
A link to the config: http://ow.ly/ybjC307xhpz
wifi0 is the 2.5GHZ interface which I have disabled ampdu and set all the cell phones with wifi to only to connect to that interface. All other devices connect using the 5GHZ wifi1 interface. It is mostly default settings except I disabled the 40mhz channel option. In my previous testing, I had changed every combination of rtsThreshold, fragLength, and ampduAggrLength. Nothing made a difference. I didn't test disabling wmmSupport, but as far as I know, wmm is required for 802n which means disabling it would reduce throughput greatly.
My current configuration is stable (cell phones on wifi0 with ampdu disabled and everything else on wifi1 with defaults). But this should not be necessary for a $300 enterprise AP.
