esaym
Dec 22, 2016Aspirant
WNDAP660 Connectivity Issues
I'll try to keep this story as short as possible. I run a small office and about two years ago I upgraded an older netgear G only access point to a newer WN203. All was well for about a year. Then I...
- Apr 20, 2017
So since the firmware upgrade and a factory reset this has been working.
DavidTunstall
Jan 20, 2017Aspirant
Thanks for your suggestions but as stated previously my WNDAP660 locks in BOTH 2.4 and 5GHZ with AMPDU enabled with 20/40 Dynamic Channel Bandwidth.
Currently the ONLY thing that fixes the problem is disabling AMPDU.
My 2 WNDAP660's have now been running for 2 weeks without issue.
However as esaym says this is not really acceptable for a business class router with 802.11n.
This looks like a firmware issue to me with AMPDU handling. All the suggestions so far do not fix the locking of the channels except disabling AMPDU.
Is this accepted by Netgear as a bug right now?
Regards
David
zappullae
Jan 21, 2017Aspirant
So far I'm a week in and problem free. I only have disabled WMM power save and have AMPDU enabled. The other differences in my network are that the Comcast router is in Bridge Mode. Previosly it was not and I had just turned off the radios. And I don;t have a Firestick connected to my TV any longer. I'm not sure if those items effected the operation of the WAP.
